mx6 brake help! ASAP
Old May 22, 2009 | 01:34 PM
markstheman365's Avatar
cant slide
Default mx6 brake help! ASAP
hey, my pads felt like they were wearing down(to the point were the pedal hits the floor, and barely slows the car down.) so i changed my pads and bled them they worked good for a day or 2, then i let my car sit for 2 days and now the pedal does nothing. i push it to the floor and it doesnt even slow it down a bit. anyone that can help me, pm me or text 813 679 1441. i will pay
contact admin@tamparacing.com to advertise on here.. - mod
Old May 22, 2009 | 03:44 PM
MazdaMX3Freak's Avatar
Vtack THIS!!!
you either have air in the lines. your master is going out. or when you did the brakes you messed up the pinion in the caliper. more then likely theres still air in the lines.
-2008.5 Mazdaspeed3 CWP
Old May 22, 2009 | 06:06 PM
cant slide
the only one that has air in the lines is the passenger front. but it seems like there is soo much air that bleeding it isnt enough i was pumping it for like 10 minutes and it was strate air coming out. all the other 3 were airless. wouldnt the 3 brakes work then that one wouldnt or would it screw up the whole thing
Old May 22, 2009 | 06:38 PM
Super6's Avatar
santa fe pimp
Do you have your calipers upside down sounds funny but Iv seen it happen. Air bleeder facing up on the caliper
Old May 22, 2009 | 06:52 PM
.Patrick.'s Avatar
Has twenty valves
my guess is the master cylinder is bad. even if your pads wear all the way down your pedal will stay at the same height.
Old May 23, 2009 | 03:41 AM
cant slide
but it was wierd bc i put new pads on and it worked perfectly for about 2 days
Old May 23, 2009 | 05:26 PM
Super6's Avatar
santa fe pimp
Yeah what pat said cuz we go to school
Old May 23, 2009 | 07:37 PM
cant slide
dammit
Old May 27, 2009 | 06:31 AM
Super6's Avatar
santa fe pimp
If you still need help I would PM Pat
