rx-7 problem
Old Dec 18, 2008 | 08:58 AM
tito_12a's Avatar
Default rx-7 problem
the car starts but quickly turns off. my dad had the fuel pump set in a way that once i turned the key in the ignition to ON it would start pumping fuel, then i would turn the key to start and start the car, now when i do it, the fuel pump makes a weird noise, the car turns on but then quickly turns off.
the car is a 1984 and has a 12a.
R.A.P.S member number #0004
Rotaries
Against
Piston
Swaps
Tampa Bay Rotary Owners ClubMember # 5
Originally Posted by Empire
a girl just got identified by an ass pic...
that seriously just happened...
Tr is great.
Old Dec 18, 2008 | 09:34 AM
TheCamel's Avatar
how long does the car run for before shutting off?
Check all your fuses as well.
Rotaries are 20% motor, and 80% tuning
Old Dec 18, 2008 | 05:10 PM
Da_lurker's Avatar
what kind of noise? what is your fuel pressure? does it start quickly? long crank? bogg and die or just shut off?
Old Dec 18, 2008 | 05:17 PM
93LowBody's Avatar
TR Balla Donor Supreme
Its carb`d so it should only have 7psi +/- 2-3psi.
Does it start back up and run fine ?
What kind of FPR do you have ?
Old Dec 18, 2008 | 05:43 PM
tito_12a's Avatar
it turns on, then, in less than a second it turns off.
thats why i also think its my ignition switch.
Rotaries
Against
Piston
Swaps
Tr is great.
Old Dec 18, 2008 | 05:50 PM
93LowBody's Avatar
Is it loosing anything else ? Like power to the lights or radio.
It could be the fuel pump relay going bad, Its electrical for sure.
Not a fuse because then it wouldnt start at all.
Its hard to figure it out online, maybe we can look at it sunday.
Old Dec 18, 2008 | 06:12 PM
tito_12a's Avatar
radio still works.
Rotaries
Against
Piston
Swaps
Tr is great.
Old Dec 19, 2008 | 12:57 AM
TheCamel's Avatar
http://www.wankel.net/~krwright/file...g_Diagrams.pdf
scroll down to 50:14 that's the 12a wiring diagram for the circuit
If you were not getting power to the relay, then you would not have coil power either.
The more I look at the circuit, the more it could be the ignition switch
Old Dec 19, 2008 | 07:44 AM
1sleeping7's Avatar
"a beautiful man"
^^^^^before you do anything.........is there gas in the car?
Old Dec 19, 2008 | 08:28 AM
tito_12a's Avatar
hahaha (in a very sarcastic manner), yes.
Rotaries
Against
Piston
Swaps
Tr is great.
