KLZE swap?
Old Mar 7, 2008 | 08:06 PM
skitz757's Avatar
Default KLZE swap?
i have a miata and i looking at swaps and i woundted to know if a KLZE would drop right in and if i could use the stock tranny or what?
Old Mar 7, 2008 | 08:25 PM
Captain Fap'n's Avatar
Fap Fap Fap
if you don't know that the miata is rwd you shouldn't look at swapping a motor.
the klze is a probe/mx6 motor, both cars are fwd.
with that being said why are you looking at swapping the motor? what year is your miata, what are your main goals (hp,drag,drift,autox)? manual or auto transmission? there is alot of info you should give that will help us to help you. welcome to the board and remember we're here to help
Old Mar 8, 2008 | 06:18 AM
skitz757's Avatar
its a 1993 stick 5 speed and im looking to up the hp alot with out doing to much fab work
Old Mar 8, 2008 | 06:36 AM
power2weight's Avatar
-eats the last cookie.
Yes, there is at least one up and running.
Do you really think it will just 'drop right in'?
"They must really feed each other to the lions down there........"
Old Mar 8, 2008 | 02:54 PM
MazdaMX3Freak's Avatar
Vtack THIS!!!
its not a direct swapp but with a rx-7 tranny it can be done. But i think the main problem is that motor is not ment to be inline so its oil passages arent at the right angle which is no good.
-2008.5 Mazdaspeed3 CWP
Old Mar 8, 2008 | 04:43 PM
Fap Fap Fap
^^ exactly. it's really not worth the hassle, or fabrication work. the 1.6l in your car has tons of turbo kits for it. they make decent numbers and 200rwhp is more than enough in a 2200lb car. depending on what you really plan on doing with it will say if you "need" the higher numbers
Old Mar 10, 2008 | 05:31 AM
Niburu's Avatar
Sic semper tyrannis
I'd have to agree with everything said so far either:
turbo what you have
or
start thinking rotary
2011 Subaru Forester - the daily driver kid hauler
1990 Miata - track whore
LOVE THIS TAMPA CAR RACING SCENE
Old Mar 18, 2008 | 08:50 PM
Rotor_Rick's Avatar
^^^^ I love that Idea!!!
