problem with the FB
Old Jul 29, 2006 | 03:11 PM
nofu's Avatar
Default problem with the FB
im not understanding this but i lost power to an ignitor and i replaced it i got the power but the rpm tach is not moving at all still could it possibly be the distributor working half ass? or something?
Old Jul 30, 2006 | 10:03 AM
nofu's Avatar
bump!
Old Jul 30, 2006 | 11:32 AM
nofu's Avatar
can anyone just help me out here and list out the possibility of why the rpm tach wont work?
Old Jul 30, 2006 | 12:02 PM
TOBYOTA's Avatar
Try another ignitor.
Very Proud Member of R.A.P.S
R.A.P.S member number #0004
Rotards
Against
Piston
Swaps
http://www.myspace.com/tobyota
Old Jul 31, 2006 | 01:21 AM
Rotary7's Avatar
Get Down-Or-Stay Down
ignitors dont burn out easy,you sure the gauge is not bad?
So if the ignitor is giving spark,its got to be the gauge.
If the ignitor is not giving spark.Try a temp power and ground on the ignitor.I had this problem in the past.I forgot what I did.
Do you want to be tazed?
Old Jul 31, 2006 | 11:02 AM
nofu's Avatar
okay well i was thinking that it could be that instead i was just hoping it might be something else cause i checked fuses and replaced both ignitors i got a aftermarket gauge sitting here and i hate to have to use that
Old Jul 31, 2006 | 03:48 PM
TOBYOTA's Avatar
I have had the trailing ignitor give spark,But the tach not work.And then put another one on and the tack worked.I have some if you want to try them.Or put 2 msd's on and then you are good to go.But the tack could be bad.And also all the fb's ive had have had some wireing problems also.
Goodluck.
Rotards
Against
Piston
Swaps
