Injector cleaner recommendation?
Old Mar 17, 2006 | 10:20 AM
CrypticApathy's Avatar
OH SNAP!
Default Injector cleaner recommendation?
Just wondering what kind everyone uses?
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
Old Mar 17, 2006 | 10:43 AM
Rotary7's Avatar
Get Down-Or-Stay Down
theres only 1 way to clean yoru injectors.
Take them out and have them cleaned and blue printed.
I personally think "injector cleaner" you put in the tank is a crock of shit.
Do you want to be tazed?
willjs7's Avatar
im with tony, crock of shit
Andrew-
www.autoliftplus.com
Your neighborhood do-it-yourself auto shop!
Old Mar 17, 2006 | 04:31 PM
Rotary7's Avatar
If you are seriuos on gettign your injectors cleaned.Theres a place that will clean them cheaper than RC,and will have them back to you in a few days and about $10. each cheaper.
I will use them soon.
Old Mar 17, 2006 | 05:23 PM
Rotary Buddha's Avatar
zero pistons
+1000000000000000000 to crock of shit.
like stated only real way to clean them is have them shipped out.
marren will do it www.injector.com. also their aftermarket injectors are great. 1680cc all the way baby.
Originally Posted by rotarykidd
you have no idea how many TR members id kill to have this car for just a day...
Old Mar 17, 2006 | 06:07 PM
OH SNAP!
i think one of mine is leaking due to flooding problems, i knew the gas cleaner wouldnt fix that problem but i didnt think it would hurt. When you get prices for them let me know. Only problem i have is i need a DD while there getting cleaned.
Old Mar 18, 2006 | 02:08 PM
AbortRetryFail's Avatar
Trunks are for corpses.
Im in the same pinch. My FC is my daily driver.
Where's that?
1986 Mazda RX7 GXL - "Champagne"
134.7 RWHP - Going slow in style
Old Mar 18, 2006 | 03:27 PM
Rotary7's Avatar
http://www.witchhunter.com/
Old Mar 18, 2006 | 05:48 PM
boostin13b's Avatar
Rotary Pirate
The only real injector cleaner that I've seen work is 3M. $20 a can. It will not fix leaky injectors, but does help with old dirty systems. It's not the fake throw in your gas tank stuff. You actually run the engine at idle straight off the bottle and use that as your fuel. Clamp off the return and pull off the feed and the fuel pump fuse. It does wonders for old systems but will not fix bad injectors. I used this on customer cars on a daily basis and on my own rotaries.
Old Mar 19, 2006 | 03:17 AM
Rotary7's Avatar
Ive used products like this working in mechanic shops and dealerships.
"Fuel system cleaner"
Clean out the carb or throttle body,I use a old tooth brush too.
Start the car let it idle,
You have to find a vacume going into the engine (I try to get one on the intake)
Set this cleaner in a bottle set up with the dripper action, let it get sucked in,but you have to adjust the valve so not to much goes in.
The say its suppose to clean the injectors.If I had a bad injector,I wouldnt depend on this method.
But I can say it does clean out carbon depostits and build up sin th ehead,block,pistions,rotors etc.
It will foul plugs.
Most shops charge $80.-$100. for this service.
