Compression test Sat Night
Old Nov 25, 2005 | 04:15 PM
CrypticApathy's Avatar
OH SNAP!
Default Compression test Sat Night
Anyone mind giving me one saturday night when we meet up? After i over heated the other day. Alot of people recommended doing one. I dont have the tools to do one. Anyone mind giving me one?
Old Nov 25, 2005 | 09:37 PM
Rotary7's Avatar
Get Down-Or-Stay Down
No one here has the proper Mazda style one to test all 3 apex seals on the rotor at once.. I also dont think others even have a hand held pistion engine compression testors.
If you did do one with a pistion tester,do you know where the PSI should be?
Do you want to be tazed?
Old Nov 26, 2005 | 10:17 AM
Rotary Buddha's Avatar
zero pistons
Compression test using a piston engine tester:
1. note battery strength. A weak battery will yield low compression results.
2. Remove both lower plugs and wires.
3. remove EGI fuse from engine fusebox.
4. have a friend floor the accelerator pedal, opening the throttle for more airflow
5. insert your tester into the leading hole
6. hold the valve on the side of the tester open
7. have your friend crank the car over for 5+ seconds.
8. observe the needle bounces. You should see 3 in succession without skips, even bounces, in roughly the 30-35psi range.
9. let out on the valve now, and let the tester reach an overall compression value for all 3 faces(highest of 3 will be displayed). 115+ is like new, 100-115 is healthy, 90-100 is getting weak(1 year or less in most cases) below 90 could blow at any moment.
10. repeat for opposite rotor. Note difference in overall compression between rotors, which should be no more than 20psi max.
Originally Posted by rotarykidd
you have no idea how many TR members id kill to have this car for just a day...
Old Nov 26, 2005 | 11:16 AM
Slotegé's Avatar
Damn I left my compression tester at work or, I would have let someone barrow it tonight....
Wanna trade car's?
https://www.tamparacing.com/forums/c...tons-more.html
Old Nov 27, 2005 | 05:03 AM
FC3Cturbo's Avatar
eats babies
110 is in great condition, 100 is pretty alright
80-90psi is flooding problems but once it gets below 80 it's toast.
I got those from Kevin at RR, he's pretty accurate when it comes to things like this as he rebuilds rotarys as a living.
Old Nov 27, 2005 | 02:56 PM
puntorotary's Avatar
it depends on the ports also, ive had bridgeports and streetports in the low 70 psi and running strong and lasting a long time.So it aint always accurate,its a round about to see where your engine is.Unless its a drastic change then your in trouble.
STRICTLY ROTARY
Old Nov 27, 2005 | 04:53 PM
Puto's Avatar
El Puto ©
Always make sure your engine is warmed up, a cool engine always yeilds better compressions results.
