Suspension
Old Oct 24, 2004 | 06:43 PM
Mongoose's Avatar
Default Suspension
I got money to buy a new suspension (shocks and springs), which setup do you recommend? One dude that owns an RX7 told me that aftermarket suspension, makes the wheel offset wider and is no good, Is this true? His setup is stock, but he lowered the car without cutting the springs, he heated them up and compress them.
Old Oct 26, 2004 | 09:05 AM
Mongoose's Avatar
Will aftermarket suspension make the wheel offset wider?
Old Oct 26, 2004 | 12:17 PM
Jap's Avatar
Jap
VTEC Out
If you go with aftermarket suspension arms it can . Just lowering the car will not .
I would forgo the normal shock/spring setup and go with a coilover setup . Something like a Tein HE for a more track/drift oriented setup or a Tein Basic for street/looks occasional track/drift usage .
A 8/6 setup would be about optimum for a daily driven as well as drifted FC3S . You could do 10/8 on the street but it would be insanely harsh and you would be more likely to blow out a dampner .
Depending on what your going to be doing with the car i'd also recomend Mazdaspeed Diff mounts and Rear toe eliminators for the FC3S's stock active toe arrangement in the rear . It will make the car much more predictable at higher speeds .
Hondata saves lives
Old Oct 26, 2004 | 03:44 PM
Mongoose's Avatar
I will check at mazsport, hopefully they call me back.
Thank you
Old Oct 26, 2004 | 04:15 PM
Rotary7's Avatar
Get Down-Or-Stay Down
Thank you
why would you call there? they dont stock shit,you can get it online like they will..
Do you want to be tazed?
Old Oct 26, 2004 | 04:29 PM
Mongoose's Avatar
I will check more RX7 websites for more prices
Old Oct 26, 2004 | 05:21 PM
Rotary7's Avatar
I want to run KYB AGX on some RB springs,cheap.and worth it
