Exaust pipes
Old Sep 7, 2004 | 07:26 PM
Mongoose's Avatar
Default Exaust pipes
An RX7 would run better with 2 twin exaust pipes and no cat or with a single exaust pipe and no cat. I have twin pipes but I am thinking of changing them to a single pipe and no cat.
Old Sep 7, 2004 | 07:47 PM
UnIm's Avatar
It doesnt really matter. If your going to run a turbo 3'' pipe or bigger, single or duel it don't matter. Running an N/A it WON'T matter because your not pumping alot of air mass anyways. a 2 1/2 pipe or bigger, single or duel, it don't matter. plus duel is just more weight.
Old Sep 8, 2004 | 12:46 PM
1stGen7's Avatar
layin frame for life
i got 2 and 1/4 from stock manifold back no cat no nothing
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
Old Sep 8, 2004 | 01:34 PM
Rotary Buddha's Avatar
zero pistons
their is no major difference between power. a big difference in noise. turbo you want to stay a single straight pipe to prevent boost creep. n/a it really doesnt matter. getting rid of all the cats and resticve header is where you get the power.
Originally Posted by rotarykidd
you have no idea how many TR members id kill to have this car for just a day...
Old Sep 11, 2004 | 11:00 AM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
Huh? Why would a single straight prevent boost creep? It flows slightly better.
Old Sep 11, 2004 | 07:23 PM
zero pistons
to get rid of any uncessory backpressure
Old Sep 12, 2004 | 07:01 PM
Levi's Avatar
A single exhaust will always produce more power because it allows for scavenging, which is a big power producer for the Rotary.This is why the 3rdgen has this setup.
Your best setup is 2" piping make it 3"s straight from the block then 4' then collect it. then run 2 1/2 piping, you can get the 2nd gen rx7 exhaust down to 1 bend after the header collecter. and put the muffler as near the rear as possible. Use a very high quality stainless steel muffler with ceramic or steel packing, eveything else will burn out within 100 miles. or blow apart from the backfire and flames that this setup produces.
I can say this is true as we made 4 different headers for my buds rotary rail and this design was the best for low end and top end power for the 6 port 13B which ran a 12.6
custom parts is our perfection.
Old Sep 12, 2004 | 07:05 PM
Levi's Avatar
This statement is incorrect. removing stock parts does this but the single exhaust doesn't prevent creep. Creep comes from wastegate size.
Old Sep 12, 2004 | 08:06 PM
Thank you. It will actually only help it creep. A stock design will not, but throw a single 3" no cat exhaust on and see what happens.
Old Sep 14, 2004 | 07:10 PM
Mongoose's Avatar
So its better for NA and turbo to stay single no cat
