LTB 87-92 RX 7 anything I should Know?
Old Jan 28, 2004 | 02:28 AM
goinfshin's Avatar
Question LTB 87-92 RX 7 anything I should Know?
Im wanting to get a gen 2 rx7, just wandering if there are any problems with them that need to be aware of. I am really wanting the turbo II. Any help will be appreciated.
Old Jan 28, 2004 | 08:27 AM
seventhgear's Avatar
hanglike sleeve of wizard
COMPRESSION !!! lol look for the usual car things... interior/exterior level and color of fluids, vacuum leaks, someone keep adding to this list...
image removed from your sig...see forum rules
Old Jan 29, 2004 | 05:57 AM
TaMpAToNy69's Avatar
Hey You! Stay Gay!
Deinately check compression b/c you don't want to buy a damn Rotary that is going to die on you in a month due to apex seals. Lord knowns unless you know and enjoy dealing with those piece of shit 2 piece apex seals on your own and rebuilding a rotary, you'll be paying out the ass for a rebuild or new engine. Also when you take it out on a test drive push it b/c sometimes assholes put Catco cats. on them after the stock ones go bad and sometimes you end up melting the cats. and then thats a bitch to drive until you can get a new exhaust done or buy the Racing Beat shit. Do the FCs have Oil Metering pumps? I'm not too familiar with the 13B I do most of my engine work on 12As, but if so also check that leaks end up being a pain in the ass and i know when I tried changing a couple the little screws like to break. Good Luck!
Rotor On!!!
Tony
Old Jan 29, 2004 | 08:23 AM
goinfshin's Avatar
is there a way of telling if it has the apex seals? by looking at it?
https://www.tamparacing.com/forums/signaturepics/sigpic17452_1.gif
Old Jan 29, 2004 | 08:27 AM
it has apex seals !! if it is running at least and yes a 13b has an omp and s5 have electric omp's
Old Jan 29, 2004 | 08:30 AM
Levi's Avatar
Yes but you need a dental mirror and a flashlight. pull out the leading plugs and rotate the engine with a socket extention on the crank bolt, turn till you can see the seal pass by the spark plug hole, get a good look @ it, The seals should be very shiny, not dirty or carboned up, also if the comp is good you should get a sound of compression out the hole. Mkae sure you get 3 sounds per rotor as you rotate it slowly. add oil in the spark holes, and this will help it make more comp.
custom parts is our perfection.
Old Jan 30, 2004 | 08:21 AM
goinfshin's Avatar
thanks for the info guys.
Old Jan 30, 2004 | 08:59 PM
WHY_NOT???'s Avatar
rotaries, bah humbug!!!
2013 Ford Escape Titanium - grocery getting power
TR's Tactical Trunk Monkey Crew #001
Midgets and Beer!!!
the book of faces
