Draw through carb 12A
Old Oct 30, 2003 | 12:25 PM
JapDanny's Avatar
Anti-Flag
Default Draw through carb 12A
I'm setting up a draw through carb setup on my 1st gen at the shop , I will have a Holley 600 , Blue FP , T25 , hacked RB Collected street header . 3" exhaust
Will probally be running 8-10psi , any input from anyone who has done this before ? Maybe i'll buy a carb box or make my own and do blow through , I dunno .
It must be turbo !!!!
I'm going to tap into oil feed at the OMP and run premix , drain it with a tap , should be fine , run lots of 93
Fuck the Flag and Fuck you
If your going to post , please fucking think before you start talking out of your ass !
Old Nov 5, 2003 | 08:36 PM
flubyux2's Avatar
Elitist Supra Asshole :)
itll never happen, its the gayest idear evaR..
actually, youd be better off doing a blow thru if you can. buy a car box from vortech, they use boxes for their centrifugal blower kits, but would work fine on a turbo application.
anyways, i could go into details on why blow thru is better than draw thru, but i dont wanna... you just ahve to beleive me that its easier to blow than draw and Better too.
what turbo are you fixin to run?
Old Nov 6, 2003 | 05:06 AM
Levi's Avatar
I see more draw through, than those with pressurized boxes.
custom parts is our perfection.
Old Nov 6, 2003 | 05:09 AM
Levi's Avatar
You do not have enough fuel to run anywhere near 8 to 10 psi...I would go with a bigger carb, but carbs suck ass, go with FI, and tune less and make more power..lol
Old Nov 6, 2003 | 09:48 AM
flubyux2's Avatar
just cuz there are more draw thru doesnt mean its better...
remember, you cannot pressurize liquid (IE: fuel) and the long route from the carb to the cylinders makes fuel drop-out a big problem, as well as puddling inside the intercooler and pipes... not to mention you would have a HUGE problem on your hands if your car ever decided to backfire t hru the intake... IF, i said.
Old Nov 6, 2003 | 01:29 PM
Levi's Avatar
Thats one reason.
Try to make the throttle cable seal & move will using a sealed box design..umm fun...
Why not do the draw through, with out the intercooler.just use a u bend and done, bring the air under the carb?
Old Nov 7, 2003 | 10:30 AM
flubyux2's Avatar
hotpiping is Teh Suxor and promotes alot more knock than you really want on a rotary... and Vortech sells Carb boxes SPECIFICALLY for boosted applications such as this... which means they have already worked around the issue of sealing a throttle cable...so that would make sealing the throttle cable, uhm... easy.
Old Nov 7, 2003 | 11:21 AM
Levi's Avatar
Easy, If you have the money to spend..
How much is a box like that?
Old Nov 7, 2003 | 11:44 AM
flubyux2's Avatar
its expensive... $700 ish for a Vortech Carb "enclosure"
otherwise, you can get a rebuilt carb w/ new throttle shaft bushings and seals, solid fuel bowl floats, and build a carb HAT from 5.25" ID tubing w/ a nozzle welded to it for probalby under $100 which would work just as good. installs just like a regular air cleaner.
check out this thing:
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
this is the other cheap solution... you just have to make sure the carb is built to handle the pressure and doesnt leak.
Old Jan 28, 2004 | 08:35 AM
813kr$'s Avatar
go FAQ urself . . .
Go to mazdatrix.com the do alot of blow troughs. Thay have the carb hats and what nots. You can push 12 psi on stock rotors with no problem and have heard of 28 psi on a 12a pushing 680hp! Now that is what Iam talking about ! ! !
