Project Skip 9's
This is a 1997 Toyota Supra build we have going on currently at the shop. The car went 10.00 @ 145 on mid boost and one boost setting in New York where the car is from on the previous setup. Here is the dyno video from the previous setup with Alpha from IP tuning 5/1/2011 induction performance Alpha tuned 45-08r 1105whp - YouTube and 1995 Supra Dyno 1105Rwhp - YouTube . The new setup is going to consist of the following ...
- IP spec'd and built 2JZ-GTE - ProEFI Pro128 engine management system with fuel pressure sensor, flex fuel sensor, traction control and o2 sensor - JE IP spec FSM Asymmetrical pistons - JE IP spec wrist pins - Carrillo HD rods with Carr bolts - Pro Gram billet main caps - ARP main studs - HKS 272 camshafts - Ferrea dual valve springs, titanium retainers, valve locks, seats - Ferrea 1mm over valves - VW cylinder head - ARP L19 head studs - VW intake manifold - Full Race exhaust manifold - Precision Turbo CEA 8285-B turbocharger - IP downpipe - Injector Dynamics 2200cc fuel injectors - Weldon A2040 fuel pressure regulator - Walbro 255hp triple pumps - Tilton carbon carbon triple disc clutch https://fbcdn-sphotos-a.akamaihd.net...05674389_n.jpg https://fbcdn-sphotos-a.akamaihd.net...25183928_n.jpg https://fbcdn-sphotos-a.akamaihd.net...63578250_n.jpg https://fbcdn-sphotos-a.akamaihd.net...93059413_n.jpg https://fbcdn-sphotos-a.akamaihd.net...55799336_n.jpg https://fbcdn-sphotos-a.akamaihd.net...13312963_n.jpg https://fbcdn-sphotos-a.akamaihd.net...13917272_n.jpg https://fbcdn-sphotos-a.akamaihd.net...52773478_n.jpg https://fbcdn-sphotos-a.akamaihd.net...58139355_n.jpg |
