need response asap
Hey, just curious if you guys are busy tomorrow or if i could get my car towed over there for a little work.
Problem was i replaced my dizzy o-ring and thought i had it kept in the same spot but apparently i did not and now the car cranks but does not start.. also i replaced the crank pulley/harmonic balancer and need the bolt tightened to spec the only down side is id have the car towed straight to your shop however i will not be there with it and wont be able to get it until late(idk how late you guys are open) just need to know if this can be done, if no reply by tomorrow morning ill go ahead and give you guys a call to find this out.. thanks. |
pmed..Thanks
