My Poor Engine
Old Jul 4, 2003 | 07:43 AM
mike34655's Avatar
Member
Default My Poor Engine
I was driving my car when all of a sudden I heard a noise from my engine. The car died and I pulled it over. I lifted up the hood and a cam gear had broke along with my timing belt. I had it towed home. I took the valve cover off and didn't see any damage in there. Could I have bent a valve? Is there a way to check if a valve is bent without taking off the head? Please give me any info you could. Thanks
Old Jul 4, 2003 | 08:33 AM
95gsr's Avatar
AlKiF4i
Do a compression check.
AIM- Type95gsr
Old Jul 4, 2003 | 08:58 AM
mike34655's Avatar
Member
Do you know how to do that? Could you tell me what I have to do? Thanks
Old Jul 4, 2003 | 09:45 AM
Ralph's Avatar
TR Balla Donor Supreme
You can get a kit at Discount for around $40 I think. Its pretty self explanitory from there. Just remember when you turn the motor over, that you have the throttle wide open.
TR Profile
Myspace Profile
Old Jul 4, 2003 | 09:59 AM
mike34655's Avatar
Member
Ok. Thanks for the info.
Old Jul 4, 2003 | 06:09 PM
_Charles_'s Avatar
formerly 'RiceRocket'
Throttle wide open? Never heard that....
The Compression checker screws into the Spark plug hole. Disconnect the distributor, and crank the motor over 5-6 times, and check the gauge. Then move to the next cylinder. Depending on the motor, you will get readings like this:
210-210-205-210
and if you have a bent valve, expect this:
210-180-205-210
and broken ring lands on pistons would more than likely look like this:
21-75-205-210
Those are just examples. This is a very easy test....and I still don't know why you would do it "FULL THROTTLE"....doesn't make since.
BTW: The idea is to NOT start the engine, just turn it over, which is why you would want to disconnect the distributor
My Blog: www.HotRodCaddy.com
Old Jul 5, 2003 | 10:34 AM
95gsr's Avatar
AlKiF4i
A how to on compression.
Click here!
AIM- Type95gsr
