crx harness
Old Jun 10, 2003 | 03:29 PM
stockls 15.4??what's Avatar
Default crx harness
what all do i need to convert my 90 crx hf from odb0 to odb1
PLAY PAINTBALL LOCALLY
http://www.blitzkriegpaintballfield.com
^^^^^^Click There^^^^^^
Modified Racing Inc. (Blown99civicSi) John Solaro
https://www.tamparacing.com/forums/h...t=john+scammer
https://www.tamparacing.com/forums/h...acing-inc.html
Old Jun 10, 2003 | 04:36 PM
do i need just the engine harness or the inside and tailights as well
Old Jun 11, 2003 | 12:57 AM
S.crix's Avatar
d : - L ......
talk to kj at zmr he can tell u want u need
but if u ask me I would keep the pre obd for a sohc motor
if u want obd1 your looking for a wiring nightmare & alot of$$$
u GUYS can SUCK my BALLS
Old Jun 11, 2003 | 06:07 AM
KJ's Avatar
KJ
bored at work
It is not too bad. You'd need an ecu jumper harness for the ecu. You use the stock obd0 engine harness and modify the plugs for the obd1 motor.
Off the top of my head:
-Re-pin the distributor to accept an obd1 distributor
-you need to extend and change the plug for the coolent temp (fan) switch.
-injectors: you can install a set of obd0 injectors on the obd1 motor and run the wiring as is. If you run the saturated obd1 injectors you will need to bypass the injector resistor box by installing an obd1 power distribution plug.
-install the obd0-obd1 ecu jumper harness
-do the engine specific wiring, i.e) vtec wires, ect...
Old Jun 11, 2003 | 06:10 AM
how much u think all that would cost
Old Jun 11, 2003 | 06:21 AM
KJ's Avatar
KJ
bored at work
Cost for what, the ecu jumper harness is about $200. On my car I did all the other wiring so cost was $0.
Old Jun 11, 2003 | 06:24 AM
how much would it cost for me to have u do it kj
Old Jun 12, 2003 | 05:56 AM
KJ's Avatar
KJ
bored at work
I tried to pm you a price but your box is full. pm me when you clean it out.
Old Jun 12, 2003 | 08:12 PM
quicksilver EK's Avatar
The one punch machine gun
get in touch with kenji an have him make you a jumper harness
97 ITR-Mugen Equiped
04 Honda 600RR
Old Jun 12, 2003 | 08:16 PM
email.... kenji211@tampabay.rr.com
04 Honda 600RR
