wat do i need 2 go from auto 2 stick?
Old Apr 19, 2003 | 11:28 PM
Thehondafreak's Avatar
Question wat do i need 2 go from auto 2 stick?
i need to know what all i need to convert my crx from auto to stick. do i need just the clutch pedal or the whole pedal assembly from a manual crx?? im going to be swapping it with a b16a. wat clutch cable can i use??
Old Apr 20, 2003 | 07:34 PM
crackrboyracin's Avatar
Central FL Performance
i'm pretty sure all you need is clutch and crx cable for the swap as well as the linkages of coursethe crx cable should work. i am using my cable from my hatch for my ls swap someone post if i am wrong but i'm pretty sure thats it
CFP Racing
Old Apr 20, 2003 | 08:06 PM
KJ's Avatar
KJ
bored at work
You will need the 5 speed pedal assembly from any 88-91 civic or crx. Any 88-91 civic/crx clutch cable should work. Depending on the year of the car you may have to drill the holes for the clutch cable. A 90-93 teg clutch cable would probably work better since the stock civic ones are a bit of a stretch to reach the cable bracket.
