vtec gasket selection....?
Old Feb 27, 2003 | 03:24 PM
Gotin's Avatar
Sayien
Question vtec gasket selection....?
currently running a B16a, after installing a new vtec silonid gasket (from 94 del sol) it leaks less but it still leaks. I was told to use a NSX vtec gasket......? is there a differance? what so i use?
BJ
-B.J.F-
Old Feb 27, 2003 | 04:15 PM
99B16Si's Avatar
it should not leak at all especially with a brand new gasket as long as all the bolts are securely tightened. are u sure its not the distributor seal or cam seal leaking?
Old Feb 27, 2003 | 06:32 PM
01Ls-RTeg's Avatar
Genius v3.015
Originally posted by Vapor
try some hondabond on the gasket
hondabond all the way
Yes, I do talk to myself, it is the only way I can have intelligent conversations.
