injectors
Old Feb 23, 2003 | 08:50 PM
kender's Avatar
gadget man
Default injectors
what injectors should i use if I'm adding fuel pressure regulator,fuel rail, in a b16a with the stock crx si 88 fuel pump, and should i upgrade the fuel pump. I would like to get parts that could later be used in a turbo applicationas this is what i want to do
U.S.S.A Crew Member #001
Old Feb 23, 2003 | 09:46 PM
01Ls-RTeg's Avatar
Genius v3.015
the dsm will drown the motor only use them if you got turbo if you are planning on turbo charging the car wait to put them on
to use the dsm injectors you will need a resistor box too
Yes, I do talk to myself, it is the only way I can have intelligent conversations.
Old Feb 24, 2003 | 06:21 PM
KJ's Avatar
KJ
bored at work
Yeah don't switch out until you are turbocharged. Stock injectors and pump will hold out fine until then.
Old Feb 25, 2003 | 08:04 AM
ComatoseSedan's Avatar
Fo Shizzle My Nizzle
yea, even with a FPR, you can't just drop the fuel pressure crazy low to make up for the added flow of fuel from the injectors, you need a certain amount of pressure to reduce the effects of injector back pulse and such. just waite till you have a turbo.
'88 Civic Sedan - Cardinal Metalic Red
153.5 whp AllMotor
www.LHTperformance.net
