Which ECU will work
Old Jan 7, 2003 | 06:32 PM
crix's Avatar
:mugen member:
Default Which ECU will work
with an OBD0 civic
with LS vtec motor?
Old Jan 8, 2003 | 09:49 AM
crix's Avatar
:mugen member:
could you translate that to year & make?
Old Jan 8, 2003 | 09:53 AM
i-h8mytruck's Avatar
GONZO SHAPED MEMBER
88-91 JDM CRX SiR and Integra XSi.
Old Jan 8, 2003 | 11:26 AM
crix's Avatar
:mugen member:
Does a 91 LS motor have a Knock senser location?IF I was to use a SiR ecu
will I need a knock senser wired up?
Old Jan 8, 2003 | 01:40 PM
KJ's Avatar
KJ
bored at work
yes knock sensor needs to be wired up and the block needs to be tapped. There are several places on the block that are good for this. One is under the water pipe on the back of the block, the other way is to use one of the alternator mounting holes, drill it out and tap it for the knock sensor. Or just run an ecu that does not look for knock sensor.
