swapped motor idels all crazy, help!!!!
Old Jan 1, 2003 | 06:55 PM
NChatch's Avatar
i stepped on my weiner!
Default swapped motor idels all crazy, help!!!!
okay i swapped a 91 LS motor into an 89 civic DX, everything is wired up good, but it idles like it has a bad IACV but no check engine light and i even blocked off the two holes in the throttle body because it was the only way to get it to come down, worked for about an hour then it starts doing it again. all the vacuum line are hooked up, but im not sure if they are exactly correct, im still runing the dx MAP sensor, any suggestions????
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jan 18, 2003 | 08:58 PM
brian1's Avatar
CHECK YOUR FUEL RAIL
ITS NOT HOW YOU STAND BY YOUR CAR
ITS HOW YOU RACE IT........LIVE RICE
DIE RICE
Old Jan 29, 2003 | 09:05 PM
bzyrice's Avatar
Internet Car SalesManager
Default Re: swapped motor idels all crazy, help!!!!
check the TPS sensor.. I know thats what screwed my car up big time!!
Old Jan 30, 2003 | 06:44 AM
KJ's Avatar
KJ
bored at work
Yeah the wires on the tps need to be switched for the mpfi conversion, did you switch the wires? Also check the tps adjustment.
You should be fine with the dx map sensor. To make sure the map sensor is getting the right pressure hook it up on a single line to the throttle body with no tee's.
Old Jan 31, 2003 | 06:46 AM
Skunk2 LS's Avatar
my ls did that when i first put it in, i was using the dx MAP also and after i changed it to an LS it seemed to work fine.
