I Need Help!!!!!!!!!!!!!
Old Dec 27, 2002 | 04:09 AM
Stephan's Avatar
Default I Need Help!!!!!!!!!!!!!
i have a B16a in a 1990 Honda CRX and my ecu is throw codes 7, 9, 14, 23 can anyone tell me what to do to fix is problem?
Old Dec 27, 2002 | 09:01 AM
Alpha's Avatar
I don't know if this will help you but I thought I would post it for reference anyway. Good luck.
http://hybrid2.honda-perf.org/tech/codes.html
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 27, 2002 | 03:19 PM
Bill's Avatar
Livin' in Seattle
yes...take it to a mechanic
Old Dec 27, 2002 | 05:08 PM
KJ's Avatar
KJ
bored at work
sounds like you have a dx crx and whoever did your swap did the wiring wrong.
code 7 is tps, which either is wired wrong or the sensor needs to be adjusted
code 9 is cyp which is a sensor in the distributor. either the mpfi wiring conversion was screwed up or you got a bad distributor
code 14 is IACV. It may be unplugged or the valve is bad. They do go bad sometimes especially with old b16a1's
code 23 is knock sensor. Probably just not wired up or the sensor itself could also be bad.
Good Luck, if you need help fixing these problems pm me.
