Help with integra gsr 2000 catalytic converter
Old Apr 17, 2012 | 10:58 AM
patron1992's Avatar
Default Help with integra gsr 2000 catalytic converter
I plugged in auto scann and it read "catalyst system efficiency below threshold " Im guessing i need a new catalytic converter but my cas running fine no loss inpower no over heating should i replace or leave it alone
Old Apr 18, 2012 | 05:36 AM
flatrex's Avatar
crx hatch sedan
Replace it or get a test pipe if it is bothering you...they are kind of expensive to replace though unless you go with an aftermarket one which will most likely fall apart inside and start making an annoying rattle.
Old Apr 18, 2012 | 07:54 PM
2qk4u's Avatar
fuck cat converters i always chop mine off and run straight pipe
Old Apr 19, 2012 | 07:26 AM
BoostedRacerDad's Avatar
Pops
He is OBD2 so putting in a test pipe will still throw the code. Check the wiring to the O2 sensor behind the catalytic converter. You could then replace that one as it is only good for 10 years and "HOPE" it is the sensor and not the cat.
Or convert to OBD1 with a jumper harness..
But I bet this would work also....Universal o2 simulator single output [unv-o2sim1] - $40.00 : O2 Simulator, E-commerce
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Apr 19, 2012 | 02:34 PM
flatrex's Avatar
crx hatch sedan
Originally Posted by BoostedRacerDad
He is OBD2 so putting in a test pipe will still throw the code. Check the wiring to the O2 sensor behind the catalytic converter. You could then replace that one as it is only good for 10 years and "HOPE" it is the sensor and not the cat.Or convert to OBD1 with a jumper harness..But I bet this would work also....Universal o2 simulator single output [unv-o2sim1] - $40.00 : O2 Simulator, E-commerce
I didn't even think about him being obd2...wouldn't a defouler also work if he ran a test pipe?
Old Apr 19, 2012 | 08:11 PM
Pops
Flatrex you are right, a defouler should work and I don't see any problem with it because it is the secondary sensor.
JoKie TuNinG
StricKlyMT
727-510-6301
acura787
For Sale/WTB Honda & Acura
Jan 17, 2012 09:33 PM
TN96DC
12
Oct 22, 2010 05:58 AM
SAMITO RACING
10
Aug 25, 2008 05:36 PM
