90 crx si tranny+ clutch ? can i use DX AXELS?
Old Dec 5, 2002 | 07:43 PM
2qk4u's Avatar
Default 90 crx si tranny+ clutch ? can i use DX AXELS?
ok. its a 88 dx motor and im gunna put a 90 si tranny on it.
what clutch do i need to get??
i assume the 90 crx si clutch assembly but im not 100% on it so im just chekin
also frogot to ask if i had to get SI cv axels.
or can i use my DX axles
ive always had a swap and dont know alot of shit about d-series
help a brotha out. i dont want a fuckin slow dx piece of shit delivery car
Old Dec 5, 2002 | 08:14 PM
2qk4u's Avatar
also, doesnt a si ecu also go right into the dx harness.
and if i get the ecu do i need to change anything else?
it should just plug and go right? reset ecu
Old Dec 6, 2002 | 04:03 AM
Purple004's Avatar
Isn't life peachy
Default ECU
If you get a si ECU u might need to change ur intake manifold to a multiport injection if its a dual port injectoin.
im not 100% sure.....
Plus i dont no your car and im just trying to help.
Peace.....
Old Dec 6, 2002 | 08:05 AM
2qk4u's Avatar
they give u an alignment tool so u cant be off
Old Dec 6, 2002 | 02:05 PM
crix's Avatar
:mugen member:
the 88 civic/crx clutch is different from the 89-91
88 is the only year they made the clutch spline a smaller size
Use the 89-91 clutch and you will be in business
the axles are the same(SI,DX)so it will work....
HF are smaller
Old Dec 6, 2002 | 03:54 PM
2qk4u's Avatar
thanks man
just whut i needed
