Hondata tuning for B16A
Old Dec 5, 2002 | 10:03 PM
drift's Avatar
Hatorator
sounds about right.
1997 Prelude, H23A1 VTEC
Items for sale:
H22/23 block and all internal parts
4 5th gen Prelude wheels, 16x6.5, 5x114.3mm bolt pattern
More stuff for sale:
https://www.tamparacing.com/forums/showthread.php?s=&postid=472993#post472993
Old Dec 6, 2002 | 02:13 PM
RONIN's Avatar
Tetris on a stick
aren't the ctr and itr cams set with larger cam lobes for vtec? sounds like you could bump the vtec point up a bit also until tuned.
nevermind, you don't have a stage 4 do you?
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Dec 7, 2002 | 01:30 PM
RONIN's Avatar
Tetris on a stick
the problem with just bumping up the fuel pressure is that you are stuck with the setting, it can't vary like the curve would need it to. 310s will prb be fine for that application. with the hondata, john will build a map using 310s which the system will interpolate the nesc changes to run the larger injector, based on hondas original maps with the stock 240s. you could do it with the stock injectors and just bump pressure then use hondata to change the timing as well, but you are asking for injector failure on that.
when we had the blower on my ls, along with the jr boost dependant fpr, i saw pressures as high as 90psi, and had a basic hondata map with my 240s... no fine tuning vail when it hits like that
