Check engine light from hell...
Old Dec 5, 2002 | 02:56 PM
crix's Avatar
:mugen member:
Default Check engine light from hell...
READ THIS MAYBE YOU CAN HELP The car is a 92 civic CX hatch with a 92 sohc vtec motor with the Si ecu
Some one installed the Si motor and did not run the 4 wire o2 senser,
and the vtec wiring to the ecu.Im going to do that tomorrow.
The gauge cluster(CX) does not work either,it lights up but none of the gauges work (fuel,speedo,temp,turn signals),the fuel pump is not getting power unless I put power to it(changed the main relay,fuel pump, and still did not work & checked all fuses)I jump the fuel pump wire and it will run but dies when you drive normal.The fuel pressure is at 32-37psi jumping back and forth,will not stay steady.The owner said the fuel filter was less than 2 months old.It has all the original CX wiring.......
IF Anyone can help please do
Old Dec 5, 2002 | 05:46 PM
Bill's Avatar
Livin' in Seattle
wiring...check it
Old Dec 5, 2002 | 05:53 PM
cxcivic's Avatar
swapin' Hondas since '95
check the ground at the thermostat.....
K20turbo EG hatch 10.49@136
street tuned by NS RACING
??check engine light?? Tranny grinds??I fix'em!!
I MAKE HOUSE CALLS!!
SAME DAY ECU CHIPPING
I <3 WIRES
NS RACING (813)842-5517
chipped P28's $125
http://www.youtube.com/watch?v=nbsSp...a_player<br />
http://www.youtube.com/watch?v=koGfpMAvfWk
http://www.facebook.com/neal.sutton.750
Old Dec 5, 2002 | 06:02 PM
cxcivic's Avatar
or the ground under dash, on drivers side, beside your left foot.....
I <3 WIRES
chipped P28's $125
Old Dec 6, 2002 | 02:15 PM
crix's Avatar
:mugen member:
Turns out it was the wiring to the fuse box
BUT NOW I have 3 engine lights on
1.code~21 vtec (SUPER LOW oil in car)
2.code~41 heater content (does not have proper 02 yet)
3.coode~7 throttle senser (checks out Bad)
Will Code 7 make the car not rev up??????????
+ the fuel pressue is at 20psi ???
HELP!
Old Dec 6, 2002 | 06:00 PM
crix's Avatar
:mugen member:
Old Dec 6, 2002 | 08:52 PM
MattC's Avatar
Professional Asshole
true, or just snip the wire going to that annoying check engine light , and boom all the problems are solved. i swear
Semper Fi
Aim and Yahoo- Inkedupordie
Old Dec 6, 2002 | 09:18 PM
crix's Avatar
:mugen member:
thanks for the educated guess...
but even if I unplug the light it still runs like shi@
