will this work?
Old Nov 25, 2002 | 04:46 PM
KJ's Avatar
KJ
bored at work
Excuse my ignorance but what year/model is ej6 (not used to people using the correct usdm model id)? The only models that a 90-91 integra harness would work for are 89-91 hf/si's. 88 hf/si's with the changing of the drivers side shocktower plug.
Old Nov 25, 2002 | 05:35 PM
KJ's Avatar
KJ
bored at work
Originally posted by "RavageEJ6"
98 civic dx coupe
with 94-95 b18b
with pr4 ecu
hondata s200 (boost)
will the 90-93 teg harness work
Nope you will want to use your stock dx engine harness on your ls motor. Due to the way the intake manifold is set up on the obd2 dx's most of the wires/plugs will need to be extended to fit the ls intake manifold. The three wire eacv plug will need to be converted into the two pin plug the ls uses. You will need an obd2 to obd1 ecu converter harness to run the obd1 ecu.
pm me if you want to buy one of the ecu conversion harnesses.
Old Nov 27, 2002 | 04:46 PM
Silver EG's Avatar
The Mole
nevermind, i was wrong
