D15b Engine Harness
Old May 24, 2011 | 09:29 AM
addisonzawada's Avatar
Default D15b Engine Harness
Any ideas on the best place to get an engine harness for a D15b. Doing a swap and my old one is for programmed fuel injection. The new one is Electronic... Any help would be great!
Old May 24, 2011 | 04:06 PM
88_Hatchy's Avatar
I'm cooler than you
Modify your stock harness.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Jun 3, 2011 | 12:03 AM
So which did you go with?-Bob
Old Jun 4, 2011 | 01:46 PM
dippincrx's Avatar
save the s.o.h.c
if your going to switch to multi port you can modify you harness. just the the injector harness wiring off a civic/ crx si and resistor box (cut as few wires as possible). you will also need a crx/ civic si distributor and ecu. (im selling those to on the cheap) you can also just use the jdm d15b injectors and find odb1 injector plugs and not worry about a resistor. pm me if you need help
Kung.
For Sale/WTB Honda & Acura
Oct 6, 2009 08:13 PM
elmcityrican
Sep 1, 2008 08:39 AM
yellowrice
May 17, 2006 09:02 PM
skunkdSiR
4
Feb 5, 2006 10:59 AM
