Problems with my car...
Old Oct 9, 2002 | 11:44 AM
2qk4u's Avatar
this wont help your problem but maybe you shouldnt be building motors.
thats ALOT of shit to have go wrong.
when i put my 1st motor together the only prob i had was the battery died
but thats not my fault.
ppl arent gunna want to trouble shoot shit they did not put together.
its a pain in the ass.
your the best bet to fix it, since you did all the putting together.
once agian im not tryin to be a dick so dont get all pissy plz
Old Oct 9, 2002 | 12:19 PM
2qk4u's Avatar
why dont u just take it back to the fucker who built it?
Old Oct 9, 2002 | 05:26 PM
Bill's Avatar
Livin' in Seattle
Default Re: Problems with my car...
The timing belt for one, seems horribly lose
- Retension it. Simple but a pain in the ass.
Secondly, My injector O rings (on the manifold side) are screwed up causing some serious vacuum leak.
- If you smell gas then the O-rings are fubared, otherwise the leak is elsewhere. If it's the O-rings, simply drop by ACE Hardware and pick up some new ones.
Exhaust leak on the manifold... aparently my turbo manifold has become warped, perhaps from me taking it on and off so much.... it now leaks fairly bad.
- Manifold wouldn't warp from simply unistalling it. If you believe the flange to be warped, simply remove it, check the trueness of it. If it's not in spec, simply slap it up against a grinding wheel or however you want to go about it.
Car bucks and hessitates... this may be due to the vacuum leak. I am not sure. I put the old stock injectors, and it cleared this problem up..... Once I put the RC 310's in again. It started again. *shrug*
- If the stock injectors cure the problem, leave 'em in until you fix the rest of this shit.
Leaky return line...
- Run over to Amazon Hose and get a new one.
I can't seem to get the car to idle well... the head makes serious noises if I move the valve lash to stock cam specs, and the car doesn't seem to run right
- Make sure your cam timing is right.
The check engine light comes on, does not blink if you jump the ECU to trap a code.
- Sure you're jumping the service connector and not something else? If the MIL comes on, it will blink to give you the DTC if you jump it right.
