''Help on Pulley Removal''
Old Oct 6, 2002 | 07:26 PM
C VeX's Avatar
Default ''Help on Pulley Removal''
Im trying to loosen the pulley bolt to do a timing belt change on my accord v6 . I've wedged the flywheel with a screw driver , slap on a breaker bar , and an extension pipe on top of that. That shiiiiot wont even bother to turn.Is the thread for the bolt backwards? I dont want to spend money on an impact wrench or taking it to some lousey mechanic. Any suggestions?
Old Oct 7, 2002 | 07:53 AM
KJ's Avatar
KJ
bored at work
If you can't get it off with the breaker bar then go to a mechanic and just give him like $10 to break it loose for you. Then just tighten it enough for you to get home and do the t-belt change yourself.
Old Oct 11, 2002 | 09:24 PM
Hybrid Theory's Avatar
i know what your going through man and it sux... but luckily my dad has mad tools and i am able to use a 1inch impact. i know most peeps arent as lucky as i am but what kj says would probably be your best bet cuz i dont think you wanna go buy a 1inch impact just for one nut and i know they arent cheap
Old Oct 12, 2002 | 11:55 AM
civicracer901's Avatar
B16ACRX
what is the name of the tool called that does this. Just curious it sounds like a must have for people who do there own work. I have a little imapct driver, is that the same. I use it to remove my rotors.
Old Oct 12, 2002 | 12:04 PM
no the little impact probably wouldnt work cuz like i said i use 1 inch impact and that thing is huge its what my dad uses to work on the semi's at work its a little bit of a over kill but hey its the only thing at the time that could get the job done
