im stuck need help
Old Mar 3, 2011 | 02:55 PM
Skee's Avatar
Default im stuck need help
im lost i checked everything on this car its a obd2 b18b1 swap in a ek
just rebuilt the motor car wont idle right
it runs but when i turn the steering wheel the car stalls i messed with the idle screw and cable
the odd part is if i go down the line pulling 1 spark plug at a time see if it dies i get to cylinder 3 and it does nothing no idle change or anything i pull the other 3 and it wants to die out so i went ahead and started unplugging injectors and same thing cylinder 3 the idle goes up when i unplug the injector the other 3 motor dies out
whats the deal with cylinder 3 anyone seen this issue????
it has spark cause it sparking when i remove the plug i changed the spark plugs to
Custom high amp Alternators.. pm me
Old Mar 3, 2011 | 03:44 PM
NeKe1point0's Avatar
compression check number 3
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Mar 3, 2011 | 04:13 PM
Skee's Avatar
hmm motor has like 2 miles on it but ill run a compresson check 2mmaro any other sugguestions besides that
Old Mar 3, 2011 | 05:06 PM
Skee's Avatar
also when i plug in the iacv it sounds like a dam vaccumm lol when i take it off its quiet it makes some dam loud intake hummming sound when its plugged in i never hurd that befor well atleast that loud
hateshino
Aug 11, 2007 06:20 AM
Philly Blunt
Jul 25, 2004 07:12 PM
teenagegirl
The TRuck Forum
4
Jun 9, 2004 12:26 PM
SickOfAlltezzas
Apr 19, 2004 10:47 AM
