timing? someone please help me
Old Feb 25, 2011 | 12:56 PM
HondaManEX's Avatar
Default timing? someone please help me
ok so the car is a 98 civic lx with a d16y7. i just replaced the head gasket and its runs very smooth but it doesnt drive. and what i mean by that is that the car will move under its own power (its an automatic) but as soon as i give it some gas it will bog down really bad. if i kept my foot on the pedal it would stall out. also it will let u use the gas very small amount until 2k rpm and then the car will start to buck unless i put my foot under the pedal and pull it so it can stop any tips help. and before anyone asks there are no lights being shown on the dash.
Also helpful replys will get REPD
SIG?
Old Feb 25, 2011 | 01:00 PM
Alswizzo's Avatar
The Underdog!
is your timing dead on??
it sounds like TPS or MAP sensor
go back and double check your timing and make sure all your sensors are plugged in correctly and that you didn't mismatch the TPS and MAP sensor plugs.
Old Feb 25, 2011 | 01:03 PM
HondaManEX's Avatar
which plugs are those? haha and would the car do tht if i had the plugs backwards?
SIG?
Old Feb 25, 2011 | 02:15 PM
HondaManEX's Avatar
lol nvm i got it i had the plugs backwards it runs fine now. thanks for all the help much appriciated
SIG?
Old Feb 25, 2011 | 04:02 PM
Alswizzo's Avatar
The Underdog!
glad i could help.
Batman4ever
Feb 26, 2008 07:23 AM
JDMciVic
Feb 8, 2006 04:26 PM
CBER
Toyota/Lexus Tech
Feb 23, 2005 05:33 PM
99B16Si
Apr 4, 2002 07:40 AM
