Cluster not working...
Old Feb 17, 2011 | 10:14 AM
Ls_[eg]hatch's Avatar
mowchowbrowncow
Default Cluster not working...
okay so i recently did a tranny swap on my eg hatch & i also pulled out my oem cx cluster & put in a edm Eg cluster.
When i got my car done & drove my car all lights,gas,temp,rpm,speedo all worked fine...Well later that night i go to get on it a little bit & almost as soon as my car crosses over everything except the lights stopped working, Gas went all the way up,Temp went all the way down Speedo & rpm stay on 0.
But light i said all of the cluster lights work fine.
Checked my fuses & VSS everything there was fine.
Any ideas?
Old Feb 17, 2011 | 10:31 AM
flatrex's Avatar
crx hatch sedan
Yikes I hope its something simple. Try putting your other one in and if it works fine then possibly the cluster itself has an issue
Old Feb 17, 2011 | 12:33 PM
integra's Avatar
90% grind 10% sleep
ground?
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Feb 17, 2011 | 08:46 PM
BoostedRacerDad's Avatar
Pops
^+1
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Feb 17, 2011 | 09:09 PM
LShatch98's Avatar
i love making you mad <3
^^^im with them.
Proven Power for all your go fast needs
Old Feb 17, 2011 | 09:20 PM
Pops
http://www.marklamond.co.uk/products...luster_jdm.pdf
Pretty sure this is what you need to troubleshoot
JoKie TuNinG
StricKlyMT
727-510-6301
Old Feb 18, 2011 | 03:09 PM
mowchowbrowncow
thanks alot pops!
ima check everything out when i get home.
Old Feb 21, 2011 | 10:28 AM
mowchowbrowncow
still nothing everything in the clips seem fine, & i tryed my old cluster is didnt work either...ughhh
Old Feb 22, 2011 | 05:57 AM
Pops
Replace fuse #15 10amp in under dash fusebox. I think it is labeled backup/lights. That should do it, if not PM me.
JoKie TuNinG
StricKlyMT
727-510-6301
Old Feb 22, 2011 | 05:59 AM
Alswizzo's Avatar
The Underdog!
Check your grounds
Tranny to chassis ground, T-housing Ground, etc.
everything going over to Hot and full is def a ground/short.
