90 si swap questions?
Old Feb 2, 2011 | 07:17 PM
dragon13's Avatar
Default 90 si swap questions?
I'm getting a 92 b18a a/t complete swap from my buddy for free and the only thing i'm paying for is for the ys1 m/t tranny. do i have to change the flywheel or is it the same?
I hear that for the swap u need to convert from dpfi to mpfi. but i have a 90 civic si hatch and i think is mpfi. So what do i need to do? Someone told me that all i need is the ecu jumper from obd0-obd1 and that should work. I want to do it right so please let me know.....thanks
Old Feb 3, 2011 | 08:56 PM
b13steve's Avatar
you do have to change the fly wheel to a m/t ( make sure you get the 6 bolts out of the m/t fly wheel because you have to use those ). no need to convert to mp.......you have a si car which is already mp. and yes you do need jumpers to run an obd-1 engine. you need the dizzy jumper and a ecu jumper. another factor is......your injectors. obd-1 has saturated. you need peak and holds. commonly found in obd-0 b-series cars. ( 90 and 91 teggy or 90 model prelude ). i have this exact set up in my crx si.
JDMinnovations hollywood, fl
93 del sol.....z6 on 8psi......201...daily beater
91 talon tsi.....25psi.......467...weekend sleeper
I do DP to MP swaps and full obd-1 for EF
352-364-6384
Old Feb 4, 2011 | 03:55 AM
dragon13's Avatar
thanks
Old Feb 5, 2011 | 01:01 PM
88_Hatchy's Avatar
I'm cooler than you
Everything you need to know:
http://www.performanceforum.com/wesv...ng/wiring.html
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Feb 8, 2011 | 09:47 AM
dragon13's Avatar
where can i find an downpipe to fit the b18 and it will bolt on to my converter
Old Feb 8, 2011 | 04:03 PM
88_Hatchy's Avatar
I'm cooler than you
nowhere
