integra fans won't work!need help please!
Old Jan 18, 2011 | 08:01 PM
lsvtec34744's Avatar
Default integra fans won't work!need help please!
i have a 96 integra with a b18a1 block in it. after doing the swap the ac and radator fans do not come on. i jump it and the fans come on but when i plug it back in the fans dont work.help please!
Old Jan 18, 2011 | 08:13 PM
Korean Racer's Avatar
i had the same problem in my CRX. Heres what you can try take some wire and connect it to the fan and than connect to other ends to a positive and a ground. if the fan kicks on than you have a bad connector. If it doesn't than the fans motor has gone bad. Hope this helps
Old Jan 19, 2011 | 04:29 AM
Alswizzo's Avatar
The Underdog!
check the relay and fuses under hood.
Old Jan 19, 2011 | 05:56 AM
integra's Avatar
90% grind 10% sleep
move the thermostat ground over to another spot.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jan 23, 2011 | 11:29 AM
freakasis's Avatar
unplug the 2-wire connecter thats on the thermostat housing and with the key on jump the wires and see if the fan comes on. do that AFTER checking the fuse and relay in the under-hood box.
"Black people can't be racist" - Some black guy.
