95 eg fog light help!!
Old Dec 14, 2010 | 02:17 PM
chuck07's Avatar
Default 95 eg fog light help!!
so i bought some fog lights off ebay and installed them but for some reason one wire keeps burning up. its the yellow wire that comes from the relay to the lights that keeps burning up?
please help i have no idea why its doing it
Old Dec 14, 2010 | 02:51 PM
BoostedRacerDad's Avatar
Pops
Check wiring. Did you wire it exactly like this?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Dec 14, 2010 | 05:27 PM
chuck07's Avatar
sorda from the fog lights it had a red wire that came from the relay on the pass side that i hooked to the batt. then on the driver side it had a black and red wire and i grounded it to the chassy and the other had a male end connector in it that was run threw the fire wall i have three wires come from the switch are RED YELLOW AND BLACK the black i have grounded the yellow i have to the fuse box and the red has a female end which i pluged into the male end that i fed threw the fire wall. everything worked then the next day they did not and the yellow wire from the relay to the lights was burned up. so idk
Old Dec 14, 2010 | 05:29 PM
chuck07's Avatar
and thanks for the pic ill try to re do it all tomm
