LS Turbo Cams????
Old Nov 27, 2010 | 05:41 AM
CrXSibeast's Avatar
Default LS Turbo Cams????
hey guys im gonna be going LS-T and to know what are good cams to use, ive heard alot about the crower cams but are there any other good kind to use???
TR "Old Skool DA" Member #39 Crew
Old Nov 27, 2010 | 10:31 AM
mtber's Avatar
There are a ton of factors to think about when choosing a set of cams for a turbo vehicle.
Your best bet is to ask who ever is going to tune the car... Asking some idiots on a forum will get you no where.
I would need to know what size turbo your going to run, how much power your going to try to make, what turbo manifold your going to use to even give you an opinion on a good choice.
FYI: Stock cams work perfectly fine for most ls-t setups under 300 whp.
Old Nov 27, 2010 | 12:56 PM
88_Hatchy's Avatar
I'm cooler than you
Big all-motor cams make big turbo power, properly degree'd that is.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Nov 29, 2010 | 11:02 AM
Paulino's Avatar
Not harsh, just truthful
Crowers 404 cams with matching valvetrain won't disappoint no matter what the setup if your staying ls.
