Engine Help with my 96 accord
Old Nov 16, 2010 | 01:57 PM
cubanguerrilla's Avatar
The Barbo-Bot
Default Engine Help with my 96 accord
Hey guys just wanted to see if anyone could give me some pointers on this issue with my 1996 accord 5 spd F22A
When I am at idle and start to drive in first gear the car bogs for a few seconds and i have to hold the clutch and rev a couple times to get it to drive. after I do that, it drives just fine. Also, probably related, when i go in reverse it does the same thing, but bogs worse and when I turn the A/C on it idles extremely low and shuts off after a few seconds.......I have replaced the spark plugs already, any other ideas?
2003 350zTT (346rwhp) - Sold
1991 300zx TT Stage 5+ (412rwhp) - Sold
1991 300zx TT Stage 3 - Sold
1990 300zx TT - Under Construction
Old Nov 17, 2010 | 07:15 AM
DRMORTY's Avatar
Once Ruled The World .l..
check for codes
TR
"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
Old Nov 17, 2010 | 12:30 PM
The Barbo-Bot
ok went to autozone to have the car checked for codes, but i guess the code machine didnt work.......the cluster on the accord does not work, so I am assuming that is why there are no codes being read on the machine. I am googling the make up of the fuse box on the 96 accord to see if maybe i have a blown fuse.
Do you think the cluster may be bad? is that possible>?
Old Nov 17, 2010 | 04:16 PM
NeKe1point0's Avatar
IMO sounds like the car is out time.
The engine has obviously been swapped since you have the F22"A" not "B".
Did the car run normal at one point then recently start this issue ? Or has it always run this way since the swap took place.
Would need more info to help you with your problem.
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Nov 18, 2010 | 12:56 PM
The Barbo-Bot
Honestly I could be wrong about the engine that is in there, how can I check the engine so I can verify the engine that is in there. The problem with the car has been there since I purchased it last week Let me know what other information is needed! I am going to check fuses this weekend!
