Compression test result & a question
Old Aug 23, 2002 | 05:47 AM
hmonglonertim's Avatar
Default Compression test result & a question
Got bored at home and did a compression test on a dx motor (d15??) and got the following,
1=115
2=120
3=125
4=170
I left cylinder 4 alone because it looks ok. Added a drop of oil to the others and it raised compression right around 170. If I'm not mistaken, this means the piston rings are bad. The question I have is why doesn't the motor burn oil or blow dark smoke out the exhaust? Oh and I use 10w-30
Old Aug 23, 2002 | 10:41 AM
2qk4u's Avatar
u must not be lookin hard enufff
it has to be comin out somewherre with that shitty compression
Old Aug 23, 2002 | 12:00 PM
Oil will stay at the same level. Someone else from another board suggested that only my compression ring was bad causing the compression to go up when oil was in the chamber. Makes sense to me.
