idle problems
Old Oct 5, 2010 | 01:54 PM
89crxsir's Avatar
Question idle problems
92 teg ls shiny intake, header w/full exhaust, 12lbs flywheel and 6 puck clutch... it all started when i replaces my thermostat and found a hose going to the IACV leaking.. I replaced it and now the car rshared_pm jumps form 2k to 800 to 2k to 800rshared_pm for a bit, then settles down.. sometimes it will not do it at all.. the throttle body gasket is okay.. anywhere else to look??
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Oct 5, 2010 | 04:14 PM
hondachris1994's Avatar
hatchback1994
bleed the coolant, it seems u have air in the system still
Old Oct 5, 2010 | 06:49 PM
01LatinVizionGSR's Avatar
^ Either that or just a simple vacuum leak somewhere.
Old Oct 5, 2010 | 06:52 PM
therecanonlybe1's Avatar
CTR Parts & Performance
replace your throttle body...
CTR PARTS & PERFORMANCE in Tampa and in New York
83 Rx-7 GS 11.80@1/4 (wrecked it)
83 Rx-7 GSL 10.50@ 1/4 (blew it up)
93 Eg Hatch w/nos 7.50@1/8 (ex wife took it)
94 Eg coupe 9.50@1/8 (re-poed cause of babymama)
99 ek sedan 11.32@1/8 (totaled it)
99 odyssey van (lowered on 19s)
Old Oct 6, 2010 | 06:01 AM
89crxsir's Avatar
I bleed the coolant a few times already.. I even had the radiator out a few months after.. No vacuum leaks. I smoked the system and no leaks
