B18c1 Engine Wire Harness Wiring help!
Old Sep 17, 2010 | 05:30 AM
whudupitskay's Avatar
Hey man its Kayman
Default B18c1 Engine Wire Harness Wiring help!
I am rebuilding my 95 b18c1 (gsr) head obd 1. I noticed that originial wiring harness was cut up. So I bought a used wiring harness, with no cuts for the motor. I made the mistake of removing the old harness first, instead of removing the old harness, plug by plug while installing the new one. So now I do not even know which plugs goes to which sensors, since some sensors use's the same pin plug and that the only way to tell the plug apart is by the color of the wires. So with that in mind, is there like a
color code to match the wire harness to the sensors, or maybe some sort of wiring diagram for the obd1 engine for the gsr, I searched all over the net and only found sites where people are selling or converting from different obd's, but nothing on replacing... sorry if i am being to technical
this is just frustrating because it is a really unnecessary error on my part.
Old Sep 17, 2010 | 06:37 AM
Hey man its Kayman
Default anybody
YouTube - PAUL VAN DYK "For An Angel"
Old Sep 17, 2010 | 09:31 AM
NeKe1point0's Avatar
We can help give us a call
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Sep 17, 2010 | 02:03 PM
freakasis's Avatar
only ones i can think of that have the same plug are the evap and intake temp sensor. and the tps and map. just try em either way until you dont get any codes.
"Black people can't be racist" - Some black guy.
Old Sep 17, 2010 | 04:40 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
if your near Gainesville PM me, i can help.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
