92 acura integra
i have a 1992 acura integra,im jus getttin into the whole honda scene,but i have been working on this car for 3 days now,and the water pump went out,so i replaced the water pump on it yesterday and set the timing on it,but the day befor tht it was running fine just kept over heating because of the loss of water from around the water pump shaft,well i took the ingectors out befor i replaced the water pump,cleaned them then it ran fine,then yesterday after i set the timing and reeplaced the water pump it wouldnt start so i pulled the injectors out again and cleaned them once more,now im completly at a loss cuz the fuel pump is working,its getting fuel to the fuel rail,but its still not running,i know its either a fuel delivery problem or a weak spark problem cuz i spray carb cleaner inside the intake and it starts up as long as your spraying it,but as soon as you quit is shuts off,so if anyone has any ideas please feel free to give me some,text perferably 813-359-4326
I would definitely recheck your timing. That car obviously ran prior to doing the timing belt so just think about everything you touched during the timing belt change and look over and recheck it all. You will find your problem somewhere in there.
