Radiator fan doesnt come on?
Old Aug 5, 2002 | 02:27 PM
civicracer901's Avatar
B16ACRX
Default Radiator fan doesnt come on?
I have already replaced my fuse in my relay box (30A) cause it was blown. What tool do I need to test my 2p contector at the radiator itself? What is this tool called? I asked for a Test Harness at advanced and they had no clue waht i was talking about? What do you guys use to test you relays, stuff like that? I need to buy one to test my fan motor etc.? please help before the part store closes thanks?
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Aug 5, 2002 | 02:28 PM
B16ACRX
Also what is jumper wire?
Old Aug 5, 2002 | 02:55 PM
Joker's Avatar
Eat My Ass With a Spoon
you need to check the temp sonsor on either the block or the thermostat housing. its usualy the one on the thermostat housing that goes bad and causes this problem. and break out the ole multi meter and helms manual and start probing your wires to make sure you are getting the right voltage or any voltage at all to said relay and or sensors.
Old Aug 5, 2002 | 03:01 PM
B16ACRX
I found the mutimeter for around 35.00 is that a good price and is this what i need also what is jumper wire?
Old Aug 5, 2002 | 04:47 PM
B16ACRX
K I was always been told you get what you paid for or if your going to get one to keep get the one you want or Cheap tools never last stuff like that. I found some Mutilmeters for as low as 35.00 and the highest would be like 160.00. I want to know cause I know they are pretty useful tools , which onw should I get? I was tempeted to buy the cheap one but didnt cause I wasnt sure if its got all the goodies I want to have or need.
