97 ITR BB/MC more pedal travel problem...
Old Sep 5, 2010 | 02:07 PM
FoxHondaRider's Avatar
Registered Hater
Default 97 ITR BB/MC more pedal travel problem...
So I installed a new 97 ITR brake booster and master cylinder (1") on my EJ8 with Stock front brakes and GSR rear disc brakes. Also installed a 40/40 prop valve. I bench bled and I bled the brakes, flushed out all the old fluid, no air is coming out, fluid is coming out real strong and steady out of the bleeder valve on all 4 corners... still the same pedal feel. The pedal doesnt sink like theres a leak or anything but its not firm. It feels like it starts to get firm way far down near the floor but it wont hit the floor. Its not super easy to push the pedal like theres no pressure but it just feels "unsafe" if I were to actually drive the car with it like that. Who knows if it will even stop. So WTF is the problem? Brake guru's, I'm all ears or eyes I should say.
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old Sep 5, 2010 | 05:02 PM
hondachris1994's Avatar
hatchback1994
Did you bleed them in the order of farthest caliper from the to closest?
Old Sep 5, 2010 | 05:32 PM
Registered Hater
Yes, I tried that. RR, LF, LR, RF. I have also tried RR, LR, RF, LF. Then tried the RR, LF, LR, RF again and then again. Still the same thing.
Old Sep 8, 2010 | 04:17 PM
HondaEatingTSi's Avatar
4G63 PWR
im not sure if the itr had the same set up as some of the newer acuras. But if it does did you adjust the pushrod for the booster correctly? I ask this because if you bought a brand new booster they dont come with the proper clearance from the factory and need to be adjusted.
Honda/Acura certified Technician
Lexus/Toyota certified Technician
ASE certified
1992 Eagle Talon TSi AWD sold
2003 Maxima SE
Old Sep 8, 2010 | 05:51 PM
95mustang351's Avatar
Default :)
yes that ur problem but dont do it too much or it will star stoping by it self good luck
Old Sep 8, 2010 | 06:57 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
are you using rubber lines?
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Sep 8, 2010 | 09:34 PM
Registered Hater
only the little sections to the calipers.
