Need help.. 3 codes.
Old Jul 25, 2002 | 11:01 AM
JTP's Avatar
JTP
Been here a while.
Default Need help.. 3 codes.
Can someone fix.. Steve and Chris figured out what codes I was throwing.
o2 sensor
map sensor
and knock sensor
for a civic hatch w/ a 95' gsr in it.
Old Jul 25, 2002 | 11:38 AM
99B16Si's Avatar
o2 sensor. not a big deal just figure out which one it is. if u have a gutted cat or no cat youll usually throw that code
map sensor. what are u using to bypass it for boost? check valves or missing link? check that
knock sensor. not a good code to be throwing. check to make sure u did accidently fuck it up when canged your oil or something. theyre really delicate. hopefully your car isnt actually knocking. no intercooler makes that a lot easier to do.
Old Jul 25, 2002 | 01:39 PM
JTP's Avatar
JTP
Been here a while.
Check PM's.
Old Aug 1, 2002 | 05:48 AM
letsrollagn's Avatar
BRT OVERKILL
o2 sensor can be bypassed if it is the secondary in the cat, knock...do you have aftermarket pistons, the rattle sets it off....if not just replace it, map just replace with a working one and see if it corrects it if so test the sensor.....
Old Aug 2, 2002 | 11:30 AM
m0nk3y's Avatar
pwns.
[quote]Originally posted by "TegPenis"
Originally Posted by letsrollagn
o2 sensor can be bypassed if it is the secondary in the cat.[end quote]
how do you do that? mine was ripped out(by secondary i hope you mean the one towards the back of the car) i will like pay you to do it if you can.
you have obd2. he has obd1.
Originally Posted by Lil Ze
Florida is the new Miami through and through.
