Tripping Cooling Fan ??
I have been using a bent fuse where the relay should be to make the fan run constantly. is there a better way ?? the fuse was held down by tape but, kept falling out. anyone have any ideas ?
my friend sean opened up his relay and rigged it ??
Anthony
my friend sean opened up his relay and rigged it ?? Anthony
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
no, i didn't clarify that
I meant is there a better way to trip the cooling fan to run all times !
i tried the bend fuse hints no relay, so it run always. i tried the spoon thermoswitch it triggars the cooling fan at a lower temp. couldn't really tell a difference. i got spoon thermostat,rad cap (doubt it really even does what it suppose to, except maybe put to much pressure in the cooling system), and 40% water wetter 20% coolent, 40% water. i'm mostly trying to find alternatives to having to buy a fluidyne for 350 bucks !!
thanx
Anthony
thanx
Anthony
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
Just figure out the voltage required on the hot wire, find a continually hot source, drop the current to required level, and splice. Simple.
On a side note, I'd take off that highpressure cap if I were you.
Plastic end tanks + age/wear + higher pressure => nice crack.
Anthony
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
currently, you have a single core radiator...right? if this is the case...and your worried about money, spend 160 from importautosalvage.com on a generic dual core radiator. i have one and it fits perfectly in the honda mounts and has been working just fine, plus it does have a guarantee.
its not worth overheating your motor because you're being cheap. believe me, its a lot less expensive when you have to swap or rebuild your motor because you cracked your head.
also...for those who are about to say single core radiators work just fine...
yes, a single core radiator will work just fine, but several people made this point to me when i was going to just stick with the single core.
honda engineers design b-series vtec's to run a certain temperature. and, with both a single core and dual core radiator if the thermostat is working well there shouldn't be any problems under normal driving conditions. however, on hot days where there is increased heat and stress on the engine the water temperature could very well rise 10-20 degrees because the single core radiator simply can't cool fast enough...because its capacity just isn't big enough. and yes, there are ways to get around buying a new radiator...which you seem to be doing by running your fan at all times. however, your fan is still not going to be as efficient as a bigger radiator with more capacity.
and the problems that occur may not be obvious at first, because the difference on your temp guage will probably be small...however, after prolonged use..ie two to three years of hard driving you increase your chances of something going wrong.
it would just suck if you blew your engine because you ran it hot...its happened to me and it sucks.
Guest
Posts: n/a
3><4c7ly. 4|\|d \^/0|2d 70 7h3 \^/153 - ju57 b3c4u53 y0u|2 73mp3|247u|23 g4ug3 d035|\|'7 4c7 4|\|y d1ff3|23|\|7, d035|\|'7 m34|\| 7h3 m070|2 15|\|7 |2u|\||\|1|\|g h0773|2. 0p71m4l c0mbu5710|\| 74k35 pl4c3 47 0|2 4|20u|\|d 160 d3g|2335.
