problem starting my b16 crx
Old Jun 25, 2010 | 06:45 PM
slowrex88's Avatar
Exclamation problem starting my b16 crx
we just got done with the swap and to start it, to start it we had to push start it not really sure if its the battery cause the lights were really low and not sure if its the starter that is having the problem or the battery please lmk what you think im checking both tomorrow i need some advice on what else i can look at
Old Jun 25, 2010 | 07:09 PM
marktopia's Avatar
TR Balla Donor Supreme
well if lights are really low your batt needs replaced anyway. so replace that and if it dont work after that then get starter. either way your battery is bad. hope you fix it.
Old Jun 25, 2010 | 07:18 PM
slowrex88's Avatar
you think that could be the problem that its not giving anough power to the starter ??
Old Jun 25, 2010 | 07:39 PM
flatrex's Avatar
crx hatch sedan
Charge the battery if it doesn't hold a charge then get a new one. Then if the starter just clicks once when you go to start it with a charged/new battery then tap the starter with a small hammer. If it cranks when you tap it its a sure sign your starter is taking a kaka.
