y8 swap in a ef. help?
Old Jun 21, 2010 | 09:06 AM
efkidd525's Avatar
I do what I do
Default y8 swap in a ef. help?
i would like to do a y8 swap into my 89 civic wagon but i only have about 500 bucks. wil it be possible?
if i got a complete y8 swap would EVERYTHING from the swap fit into my wagon?
what would i have to do?
do i gotta get my own axles or mounts or anything special?
my car is already MPFI which makes it ODO0??
TR "Old Skool EF" Member #179
Old Jun 21, 2010 | 03:57 PM
dippincrx's Avatar
save the s.o.h.c
if you are keeping it odb0 just put your injectors and distributor on the engine. you will not be able to use the trans without getting a hasport conversion mount kit. you will also need to either go with a vtec controller, pr3 ecu or chip and convert a 90/91 ps9 ecu
Old Jun 22, 2010 | 01:57 AM
efkidd525's Avatar
I do what I do
so i can use verything that comes with the y8 expect for the dizzy and injectors?
and where can i get mounts at?
Old Jun 22, 2010 | 03:36 AM
dippincrx's Avatar
save the s.o.h.c
use the mounts from your d15. if you use the y8 trans uou will need the hasport conversion mount.
Old Jun 22, 2010 | 05:16 AM
efkidd525's Avatar
I do what I do
my car is not a d15 is a d16a6
why does everyone think that? andmy car is MPFI already
