Question with injectors
Old Jun 17, 2010 | 08:16 PM
slowrex88's Avatar
Exclamation Question with injectors
ok so im going to be doing a swap into my 88 honda crx and i currently have an obd0 ls (b18a1) in it right now im swapping the motor to a b16a3 and was wondering if the obd0 ls injectors will work on the b16?? please let me know
Old Jun 17, 2010 | 09:35 PM
custom240sx's Avatar
DC Crew Member #1
Injectors are based off what computer you are using to run the motor. If it is an obd0 computer you need obd0 injectors and distributor...obd1 you need obd1 injectors and distributor.
Old Jun 18, 2010 | 04:24 AM
slowrex88's Avatar
alright cool so its nothing to do with the year of the motor and how it works right?
Old Jun 18, 2010 | 07:04 AM
DC Crew Member #1
Plugs and sensors on the motor should work with which ecu you use. Obviously you will only be hooking up the sensors the ecu reads and no others. I'm not sure if that motor has a crank position sensor or not but obviously if the ecu doesn't look for one you wont be hooking it up. That is what they make coversion harnesses for.
