1990 acura integra troubles need help immediately please
Old Jun 8, 2010 | 03:57 PM
efhatch26's Avatar
Default 1990 acura integra troubles need help immediately please
OK guys and gals i bought a 1990 b18 acura integra the car is clean and anyways sometimes the car starts up sometimes it dont theres days where i can drive it all the time but some days it dont even start up twice.. Can anyone please help me
Old Jun 8, 2010 | 04:09 PM
ThaiRacer's Avatar
i love girls
main relay
Like us on facebook
Old Jun 8, 2010 | 04:10 PM
RacingChick111290's Avatar
~Amanda Dawn~
First, let's see what normally takes to start a gasoline car engine:
1. The engine must be turned over by the starter motor with enough speed to catch. For this to happen, the battery must have enough charge, the starter motor and the starter circuit should be OK.
2. Fuel mixed with air in the correct proportion must be supplied to the enigne cylinders;
3. Spark - there must be a strong spark at the proper moment to fire the air/fuel mixture.
4. Proper timing - the engine valves should open and close in appropriate time.
5. Compression - normal compression in the cylinders is 120 - 170 psi. The engine won't start if the compression is lower than 70 - 80 psi.
Sometimes a car may have an intermittent problem, when it starts fine most of the time, but once in a while it doesn't. Such problems, that are not presented at all times, could be very difficult to diagnose. What will help your mechanic to find such an intermittent problem is if you notice when, under what conditions the car doesn't start and what helps to get it started. For example, if you notice that wiggling the ignition key helps to get the car started, it may tell your mechanic that the problem is likely with the ignition switch (very common problem). Or if the security light flashes on the instrument panel each time the car doesn't start could tell your mechanic to begin with checking anti-theft system.
SO, does any of this happen?
Will the starter crank?
Do you hear a click but the starter wont crank?
Does the security light flash when you try to crank?
Doe the "check engine" light come on when you try and start the car?
Does the starter start very slowly but the engine wont?
Battery Problems?
Smoke?
Engine Noises?
Has the car been worked on lately?
Have you drove through alot of water?
Low oil pressure light come on while driving?
~amanda dawn~
Go Gators!
*New DD* 2006 Ford Ranger (50k)
Old Jun 8, 2010 | 06:10 PM
efhatch26's Avatar
ok the car turns over but like i said the fuel pump does not kick on sometimes.. and sometimes it does.. but it always turns over the car does
Old Jun 8, 2010 | 11:33 PM
BoostedRacerDad's Avatar
Pops
Check the plug to the main relay then the main relay itself. If you have a multimeter and a soldering iron you can fix it or buy new one if you dont. If you need more info on checking and repairing Pm me.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Jun 9, 2010 | 06:32 AM
RoadRacer's Avatar
Turn 7 at Sebring
it sounds liek the main relay, if it won't start try tapping on the relay with the key on and see if the fuel pump starts
moving to honda tech
Patrick -
Old Jun 9, 2010 | 09:29 AM
gfex81's Avatar
lol. i'm having the same problem. main relay is like $90 something dollars.
Old Jun 9, 2010 | 09:37 AM
Pops
^easy fix with soldering iron, google it for step by step instructions
JoKie TuNinG
StricKlyMT
727-510-6301
Old Jun 9, 2010 | 10:18 AM
HonkeyDong's Avatar
Every dog has his day.
i got a brand new dc2 main relay not sure if it would work in a DA but lmk I'll take $50
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Jun 9, 2010 | 03:16 PM
flatrex's Avatar
crx hatch sedan
I have a main relay from an ef possibly 2 for cheap
