Car Shuts Off When Hitting The Brakes
Old May 28, 2010 | 11:26 AM
eg695's Avatar
8 ur v8
Default Car Shuts Off When Hitting The Brakes
Ok so i got this ef hatch and when you drive it and your coming to a stop the car will shut off it'll start up when you turn it on agian but i dont know why it would shut off when you hit the brakes can anybody point me in the right direction i'm lost on this matter and dont know where to start.
LONG LIVE B-SERIES
1992 Camaro-SOLD
1995 Integra-TRADED
1992 Accord-SOLD
1995 Civic-TRADED
1990 CRX Si-TRADED
1993 CIVIC- Sold
1990 DA-9- Sold
1993 Civic- Sold
1995 Del Sol V8/K KILLA- DD
Old May 28, 2010 | 05:01 PM
flatrex's Avatar
crx hatch sedan
??? Vacuum
Old May 28, 2010 | 05:09 PM
custom240sx's Avatar
DC Crew Member #1
^ exactly what I was thinking...plug the vac line running to the brake booster and retry. Be careful because you will no longer have vac assisted braking...it will be hard to stop. If your motor doesn't die after you do that, check/raise the idle rshared_pm and raise it some and clean out the idle air control valve and then reconnect the brake booster.
Old May 29, 2010 | 05:32 AM
92 CiviC H/B's Avatar
-Proud Croatian-
I had this problem and it was the battery connection at the fuse box and a ground wire, just check the grounds to make sure.
.TR's OldSkool DA Crew Member #14.
Old May 29, 2010 | 05:44 AM
civic_loner22's Avatar
ek9 mofucka
+1 ^^^
Old May 29, 2010 | 10:18 PM
FrodoGT's Avatar
Found the Vtec switch.
Im seeing wiring fault if its not vacuum related. Likely have a short.
I had a reverse light switch that would ground to the tranny every time I put it in reverse and the car would die.
Also check your battery level when it dies..seems unlikely since it starts back up, but its worth looking. if the alternator for some reason isnt providing a decent charge the battery will slowly drain (slipping belt, bad alt etc) and youll see things like the stereo and tach dying when you apply the brakes..but again the battery would be almost too dead to restart the car.
TR Old Skool EF Crew #24
Old May 30, 2010 | 07:08 AM
eg695's Avatar
8 ur v8
pretty much i wont even know when it does it cause the car is so quiet. I'll relize it cause it'll be hard to stop cause the car is off. i was thinking a vacum line i guess i'll just need to check every vacum line or something.
LONG LIVE B-SERIES
1992 Camaro-SOLD
1995 Integra-TRADED
1992 Accord-SOLD
1995 Civic-TRADED
1990 CRX Si-TRADED
1993 CIVIC- Sold
1990 DA-9- Sold
1993 Civic- Sold
