Check engine light help!!
Old May 17, 2010 | 10:20 AM
Secondz's Avatar
Built Not Bought
Default Check engine light help!!
Ok, So my car is throwing 2 codes... 22 and 7, I found out that 7 is my TPS and i cant seem to find a 22? i found a 21 but not 22
Old May 17, 2010 | 10:29 AM
jingram20's Avatar
In the work's
code 22 is a vtech pressure switch
Old May 17, 2010 | 04:07 PM
Secondz's Avatar
Built Not Bought
^ is there any way to bypass that?
Old May 17, 2010 | 04:56 PM
zhillz's Avatar
Porno Music Producer
Code22 = VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch.
Get another switch and check the wires if its getting grounded out you loose vtak
Old May 17, 2010 | 07:46 PM
FrodoGT's Avatar
Found the Vtec switch.
You can put a jumper in the plug and that should eliminate your code, if it doesnt then its in the wiring.
TR Old Skool EF Crew #24
